Idle issue
16 years 3 weeks ago #1080 by rluvsporsche
Idle issue was created by rluvsporsche
I found my idle issue after some extensive testing. I have to replace the vacuum line from the fuel tank vent diaphragm to throttle body. Is there a technique to replace this line without removing the intake manifold? Does someone know how flappy vacuum solenoid located on the driver's side front cam cover works?
16 years 3 weeks ago #1094 by srshaw3
Replied by srshaw3 on topic Idle issue
rluvsporsche;1115 wrote: I found my idle issue after some extensive testing. I have to replace the vacuum line from the fuel tank vent diaphragm to throttle body. Is there a technique to replace this line without removing the intake manifold? Does someone know how flappy vacuum solenoid located on the driver's side front cam cover works?
Have you seen this? nichols.nu/tip442.htm
16 years 2 weeks ago #1342 by rluvsporsche
Replied by rluvsporsche on topic Idle issue
Stan.Shaw@Excell.Net;1129 wrote: Have you seen this? nichols.nu/tip442.htm
Now I have. Thanks Shaw.
