Brake help! - odd problem (as usual for me)
11 years 2 weeks ago - 11 years 2 weeks ago #18505 by y33trekker
Did you ever end up replacing the vacuum line going from the booster to the intake vacuum source itself?
Maybe it's simply a matter of a rubber line deteriorating over time and not being able to hold it's shape and temporarily collapsing?
Last edit: 11 years 2 weeks ago by y33trekker.
11 years 2 weeks ago #18506 by mm928
Thanks for the suggestion. Most of the vacuum tubes were replaced with silicone but that one I believe is still original. I will look into that but pulling the vacuum is not an issue, it is more
like the release of vacuum is not happening when it is supposed too.
11 years 2 weeks ago #18507 by y33trekker
Maybe I'm not considering the operation of the booster correctly. What I was thinking is that once the booster has it's vacuum established via it's internal diaphram, a vacuum tug of war then takes place between the booster and the engine/intake vacuum that temporarily keeps the connecting vacuum line collapsed.
The following user(s) said Thank You: mm928
11 years 2 weeks ago #18508 by mm928
To be honest, I am not sure myself, indeed you may be right. I really had very little experience with brakes prior,,, it has been a very good learning experience !
11 years 1 week ago #18526 by y33trekker
Read through this one recently and wondered if a misadjusted brake pedal might still be a possibility in your case. It happens apparently.
928registry.928oc.org/forum/928-oc-techn...-front-brake-seizure
9 years 7 months ago - 9 years 5 months ago #19570 by mm928
FIXED<<<<<< Finally
Indeed (thanks goodness) it was the Brake Booster - If you have followed any of this thread we tested and worked our way back to the point that the only thing left was the brake booster. After almost a year and a 1/2 I finaly got it replaced. Just taking it out took about 1.5 hours! It is a real pain on par with the dashboard and front nose I think ... HA
I am going to a HPDE at the realtively new Domion raceway in Fredericksburg April 1st with the Va Bch PCA so I cannot wait. I have been drving minimally just to keep it road worthy with no boost hooked up. Now to ensure it is in shape for a short track day.
Needless to say I have missed the board and my car quite a bit. Although during that time, getting a new 2016 Mustang GT with performance pack has lessened the pain LOL
But I am ready to get back to Sharks in the Mountains and the Frenzy this year
Last edit: 9 years 5 months ago by mm928.
