interior lights
16 years 1 month ago #923 by john a. volak
i received a wiring diagram on the wiring of the interior lights, i think it starts at the fuses behind the fuse box. while at the body shop the lights quit working. they work if you switch them to work all the time but when you switch them to come on when door is opened they don't work. both doors do the same thing. i know the ground for the on-off feature is brown with green line. the on all the time ground is all brown. i've noticed that the red door lights do not work either. does the hatch light work along with the rest of the interior lights? any help will be appreciated. where do i start. thanks john
16 years 1 month ago #924 by srshaw3
Replied by srshaw3 on topic interior lights
several tips at Greg's site under electrical: nichols.nu/cat02.htm
Looking at the ones starting with interior, this could help you check the wiring is right: nichols.nu/tip789.htm
16 years 1 month ago #926 by Kiln_Red
Replied by Kiln_Red on topic interior lights
Do the lights work as they should when the hatch is opened?
16 years 3 weeks ago #1108 by N2O-928
Replied by N2O-928 on topic interior lights
What did the Body Shop work on? They may have reversed a wire.
16 years 3 weeks ago #1138 by john a. volak
Replied by john a. volak on topic interior lights
they were working ton body, when i showed them they did not work they had fuse box opened.
16 years 3 weeks ago #1140 by john a. volak
yes aoo worked fine.
