Need help on a spare tire question
16 years 1 month ago #902 by GlennS
Danbury, CT is fine it is about 1/2 hour from here.
Glenn Simpson
16 years 1 month ago #903 by GlennS
Stan.Shaw@Excell.Net;935 wrote: How about $75 each plus shipping, or you could pick them up (Wilbraham, MA) about 120 miles from where you are, and try a S4 spare while you are here.
$75 each is reasonable consider it a done deal. How much of a hassle is shipping? Do you have any idea what the shipping costs might be? I would consider making the trip, I'll check it out and let you know.
Glenn Simpson
16 years 1 month ago #904 by GlennS
Stan.Shaw@Excell.Net;936 wrote: I don't know that they are anything really special, do you?
I had a slow leak on a tire once, the problem turned out to be the valve. They have a rubber washer that seats against the wheel, it took some doing to find a replacement. I bought a few extras, no one local had any clue what to do about it. It was a bit of a research project.
Glenn Simpson
16 years 1 month ago #905 by srshaw3
GlennS;937 wrote: Danbury, CT is fine it is about 1/2 hour from here.
I emailed the 928er in Danbury, to see if he can help you out.
16 years 1 month ago #906 by srshaw3
GlennS;938 wrote: $75 each is reasonable consider it a done deal. How much of a hassle is shipping? Do you have any idea what the shipping costs might be? I would consider making the trip, I'll check it out and let you know.
I would much prefer to have you pick them up, as I don't have boxes for them, so packing could be problematic and expensive.
I drove the trip daily, to and from Poughkeepsie, when I did consulted for IBM. It is a 2 hour trip one way.
The big benefit is that you would see the wheels to know exactly what you are getting.
16 years 1 month ago #909 by srshaw3
GlennS;939 wrote: I had a slow leak on a tire once, the problem turned out to be the valve. They have a rubber washer that seats against the wheel, it took some doing to find a replacement. I bought a few extras, no one local had any clue what to do about it. It was a bit of a research project.
I suspect they are like these, correct?
www.pegasusautoracing.com/productdetails.asp?RecID=995
