Sunroof still stuck closed
16 years 2 weeks ago #832 by CARLO
Hi All,
The sunroof on my 83 is stuck closed. I have replaced the switch and have power to the motor. I removed the motor and transmission and it bench tested okay. I could not budge the sunroof with the motor out. I tried one of those round dent pullers with the suction cup on the sunroof and could not budge it. I finally wedged a small wood wedge between the sunroof and sorrounding body and got it to move a 1/2 inch, refused to move after that. I tried the link to RENNLIST from the 928 INTL web page and reviewed a years worth of sunroof issues but could find nothing on a stuck closed sunroof. Does anyone have a clue as to how I can get this sucker open ? Thanks.
Carlo :confused:
16 years 2 weeks ago #835 by srshaw3
Replied by srshaw3 on topic Sunroof still stuck closed
Greg's site has some tips: www.nichols.nu/tip805.htm & www.nichols.nu/tip359.htm
While it is about the 911, the photos look similar to what I recall seeing in my forays into sunroof mechanisms: www.pelicanparts.com/techarticles/911_su...1_sunroof_repair.htm
Hope that helps
16 years 2 weeks ago #838 by Brett928S2
Hi :)
I cannot remember how but I know there is a way of MANUALLY opening and closing the sunroof for emergencies....
All the best Brett :)
16 years 2 weeks ago #839 by srshaw3
Brett928S2;873 wrote: Hi :)
Yes, but if he has the motor and transmission out of it, it should just slide. At least based on my experience.
16 years 2 weeks ago #840 by Kiln_Red
Replied by Kiln_Red on topic Sunroof still stuck closed
Stan.Shaw@Excell.Net;874 wrote: Yes, but if he has the motor and transmission out of it, it should just slide. At least based on my experience.
True. Maybe there was a slight leak in the sunroof area at one time causing the rails to corrode some. That could potentially lock it up, I guess. Try some penetrating oil.
16 years 2 weeks ago #843 by JE928sx4
Replied by JE928sx4 on topic Sunroof still stuck closed
All 928 with sunroofs came with a manual crank handle for just such an instance. If your is gone, quite common, you might find someone in your area with one. You pull the cover to the rear of the sunroof and it screws in. 928 Intl may carry them.
