- Thank you received: 9
CO Test Pipe
13 years 1 month ago #15832
Replied by mm928 on topic CO Test Pipe
Ditto - there are various ways of plugging pinching, just depends on your situation and accessibility. Did mine while the engine as out.
12 years 10 months ago #16264
by N2O-928
Hi you do know what you pictured is not the "Co Test Pipe", right ?
They run directly into the Exhaust cast iron headers.
That hard metal pipe covered in foil is one of the two "Exhaust Temp Sensors" (one per side) that screw into the Head.
These are for the CAT protection system to detect Cylinder Temp difference, mostly set off by a failed Ignition bank, the system then cuts of the injectors to that bank so it doesn't dump fuel into dead cylinders.
Just don't want to see anyone messing w/ those as they run about 500 bucks EACH!
Dave K
Replied by N2O-928 on topic CO Test Pipe
928mac;16129 wrote: Mine are pinched off
Dave K
12 years 10 months ago #16266
by the flying scotsman
Replied by the flying scotsman on topic CO Test Pipe
Brad.........Dave's comments are correct.....your car is just a little different given its ex Japan.
The CO test ports are pipe thread......I installed a couple of short bolts and get rid of the pipes completely
12 years 10 months ago #16286
12 years 10 months ago #16288
by gcthree
Second Time Around 928 S4
Replied by gcthree on topic CO Test Pipe
I seem to have seen a photo where someone had put a cap on the manifold fitting, and I was wondering if anyone knew where you could source it? I fit a short bolt into the fitting and then held it in with the ferrule....but a cap would be so much nicer....
Bob
Bob
12 years 10 months ago #16296
