Coolant fans are not coming on
13 years 2 months ago #15453 by 928mac
I am trying to find out why my coolant fans will not come on. :confused:
Fans run with direct power applied.
I jump the intake sensor and the water cross over sensor, had the engine running with the AC on while depressing the hood switch but still nothing. :confused::confused:
I have bat voltage at the top intake sensor and between pins 2 n 3 at the large round fan controller plug (frt of rad pass side) but I do not have bat voltage between pin 3 n 4 which I think I am suppose to
I havent gone through all the test yet but I thought I would ask here before I go any further.
Any ideas
Thanks
13 years 2 months ago #15456 by wallyp
Check at Terminal 1 (red wire) and Terminal 4 (red/white wire) for battery power. If no power, check Fuses 28 and 29, and the medium-sized red wires on the positive battery terminal.
13 years 2 months ago #15469 by 928mac
Thanks Wally, you mean to check at the round output plug in front of the rad, Right.
If that is the plug you are referring to, terminal 4 does not have power
13 years 2 months ago #15470 by 928mac
yip #28 blowen
