Strange Brake Problem
13 years 4 months ago #14744
by rvoll
Strange Brake Problem was created by rvoll
I've got a strange brake problem on my '93 GTS. I go to a good shop (PowerTech NJ), and they cannot find the problem. The car starts shuddering for about a mile, and then I lose the brakes and the brake pedal goes down to the floor. Then, after the car rests for a while, the brakes come back. There is no loss of brake fluid and there was no warning message on the instrument panel. It sounds like an ABS failure, but wouldn't I still have a brake pedal? If there is no loss of fluid, then it is not an hydraulic problem. The car is now at the shop and does not exhibit any problems. Do any of you have any thoughts?
13 years 4 months ago #14746
by wallyp
Replied by wallyp on topic Strange Brake Problem
My approach would be to drive the car for a few miles, then feel of each of the wheels to determine the brake temperature. If any wheel or wheels are hotter than the others, I would check for failing brake lines (swelling to cut the back-flow, causing the brakes to remain slightly applied).
The suspicion is that one or more of the brakes are dragging, causing overheating and boiling the brake fluid. I would also flush the brake system, using new DOT-4 fluid.
13 years 4 months ago #14749
by rvoll
Replied by rvoll on topic Strange Brake Problem
Thanks, Wally. They already recommended flushing the brake fluid but I'll have them check to see if one of brakes is dragging.
13 years 4 months ago #14756
Replied by 928mac on topic Strange Brake Problem
Does the 93 GTS have anti lock brakes? if so, then I would pull the fuse to see if the problem goes away. It is always a good idea to check the temperature coming off the brakes which you can still do.
13 years 4 months ago #14761
Replied by pcar928fan on topic Strange Brake Problem
Brad,
Everything from '86.5 forward has ABS standard. It was optional from like '83 I think.
I agree with Wally and suspect it is one brake that perhaps has a sticking piston and is causing the fluid to boil and then BOOM...no brakes!
13 years 4 months ago #14772
by rvoll
It doesn't look like a sticking piston/caliper. Our theory now is that the ABS engaged in some way creating friction that boiled the brake fluid. Perhaps the sensors are dirty or bad. Remember there was a studdering for about 1/2 mile just before I lost the brakes. When we find the issue, I'll post the solution.
