brake fluid
13 years 6 months ago #14259 by Proton_Ice
Replied by Proton_Ice on topic brake fluid
Thanks Wallyp, i will follow your advice. It's a good ideas to change between Blue and Gold.
13 years 5 months ago #14294 by Ducman82
Replied by Ducman82 on topic brake fluid
I use the blue stuff.... :-P
13 years 5 months ago #14319 by Proton_Ice
Hi,
I buy the 1 Litter blue and the gold spair bottle for the next time..
I use the blue today and use the procedure brake bleeder.
I baught the break bleeder before and follow the procedure.
All is done now. :D
13 years 3 months ago #15241 by Vince
Replied by Vince on topic brake fluid
Is it permissible to mix BRANDS of brake fluid as long as DOT rating is the same, and not silicon?
13 years 3 months ago #15242 by the flying scotsman
Replied by the flying scotsman on topic brake fluid
Vince;15610 wrote: Is it permissible to mix BRANDS of brake fluid as long as DOT rating is the same, and not silicon?
Buy new bottles of brake fluid of the same brand and bleed all calipers and clutch with a power bleeder then you'll know for sure the system is good for at least 2 years :)
13 years 3 months ago #15284 by pcar928fan
Replied by pcar928fan on topic brake fluid
When bleeding, start with the caliper farthest away from the master cylinder and work your way to the closest caliper. I agree on the Blue/Gold idea and that brand.
