dash light replacement
13 years 8 months ago #13967
by patanna2
dash light replacement was created by patanna2
The dash lights on the right side (oil pressure and voltage indicator) are out they seem impossible to get at without removing the dash. Is there an easy way to get at them for replacing the bulbs? I don't think it matters but it's an 81 stick shift
Pat forums.928oc.org/vbulletin/images/smilies/confused.gif
13 years 8 months ago #13969
Replied by mm928 on topic dash light replacement
Nope!,,,not the dash though, just the POD,
Dwayne has a great write up on it that I used before.
dwaynesgarage.norcal928.org
Just take your time and while you are in there, check or replace all the bulbs. If they are not bad they are probably dim and yellow. You can get a kit for them from Jager Engineering among others and change the bulb style as well. He also sells kits to put a ring around each gauge,,,nice touch
13 years 7 months ago #14023
by patanna2
Replied by patanna2 on topic dash light replacement
Thanks for the info but it seems like a hell of a lot of work to replace a bulb. I think I'll live with the problem for a while.
Pat
Pat
13 years 7 months ago #14030
The first time, or even the second and third time, is a pain. After a couple dozen times, I am comfortable enough now to take my pod apart as part of the morning routine while getting ready for work.
Seriously, I would suggest doing it when you have a couple of hours to spare and you are in the mood. Odds are that you will have to or want to remove it more than once during your ownership, so the sooner you get comfortable with it the better IMO.
How is the odometer gear? That would be a worthwhile WYAIT fix that might further motivate you.
Replied by Kiln_Red on topic dash light replacement
patanna2;14388 wrote: Thanks for the info but it seems like a hell of a lot of work to replace a bulb. I think I'll live with the problem for a while.
Pat
