Easy Big Brakes For S Cars
14 years 1 month ago #10929 by OBehave
Replied by OBehave on topic Easy Big Brakes For S Cars
Jon B.;11248 wrote: Ed, What was the reasoning for the Cayenne rotors, vs. S4/GTS stuff? Cost? I'm planning on converting my car to S4/GTS spec, but if there is a major cost difference I'd be game for a set of adapters. I'm likely going to run adapters up front anyway, so, I'm just seeing what my options are.
Thing is, it doesn't look like you are using ALL of the available swept area. AFAIK, the S4/GTS setups use basically all of the available swept area. Which on the GTS is pretty substantial.
Cayenne rotors are cheap and so are S4 calipers and brake pads. I didn't want to have to buy an S4 suspension and have to swap it all over to my 85S. This way I have better than S4 brakes and MUCH better brakes than stock S. The GTS calipers can be used also but they are more expensive than S4 calipers and I wanted to stay on the cheap but have great performance.
14 years 1 month ago #10946 by Jon B.
Replied by Jon B. on topic Easy Big Brakes For S Cars
Yeah, I'm pretty interested in this then. I'm not gonna do the complete swap to my car more than likely. It's expensive and a lot of work. Brake adapters, for the fronts with S4 calipers is what I was hoping to get rather cheaply.
14 years 1 month ago #11014 by pcar928fan
Jon, I agree on the funny looking ring of unswept area...I am NOT a fan of that!
14 years 1 month ago #11034 by Ducman82
Replied by Ducman82 on topic Easy Big Brakes For S Cars
so i have the adapter for the early suspension for my GTS "big blacks" out front, and just some washers for the GTS/S4 rear calipers. will that adapter fit the early suspensions? im pretty sure thats why you made it (not wanting to swap over all that late model stuff)
pic of my mounts
14 years 1 month ago #11038 by OBehave
Ducman82;11372 wrote: so i have the adapter for the early suspension for my GTS "big blacks" out front, and just some washers for the GTS/S4 rear calipers. will that adapter fit the early suspensions? im pretty sure thats why you made it (not wanting to swap over all that late model stuff)
pic of my mounts
No it will not. This bracket is intended for use on S models only. Before,the options for S models was to buy older pre-S spindles and buy the adapter you have, or replace the whole front suspension with S-4 components. Either way you would have to change suspension parts and re-align the car.
This bracket makes for a truly bolt on and go situation for this Model 928.
This bracket however, will also allow you to use GTS calipers and Cayenne rotors so you would have a different pad and more swept area of the rotor used.
14 years 1 month ago #11039 by Ducman82
originally this car was a Pre-s or a "competition package car"
here is what i have now. works wonders. but bigger rotors are always nice.
