Speedometer vs GPS Speed
14 years 2 months ago #9929
by RGJ
Speedometer vs GPS Speed was created by RGJ
Hi Everyone,
just got a 1988 928 S4 and noticed the speed on the odometer differs from the spped indicated on my GPS.
Any thoughts as to why?
Although it has after market rims, the tire sizes front/back are correct.
Thx
RJ
Thx
RJ
14 years 2 months ago #9931
by denhamfly
I am a big boater the GPS speed should be right it is speed over ground and if you stay the same speed the delay should not matter. I would think the car mechanical one would be wrong. There should not be a big difference. The is a small delay on the GPS so if you are trying to measure ¼ mile or 0 to 60. The GPS will be incorrect. Steady speeds go with the GPS.
Replied by denhamfly on topic Speedometer vs GPS Speed
14 years 2 months ago #9932
by RGJ
Replied by RGJ on topic Speedometer vs GPS Speed
thx Denhamfly,
hmm..driving is at normal driving/ highway speeds. The difference is approx 15kms.
Can this be easily fixed?
14 years 2 months ago #9933
by denhamfly
I would not know why it is off, tires would be my first guess, but you stated that they are the correct size. I will bet you that some of our club members will be able to help you out. That is the number 1 benefit of this club, someone always has the right answer.
14 years 2 months ago #9934
by denhamfly
You can always time it from mile marker to mile maker to double check.
RGJ;10232 wrote: thx Denhamfly,
14 years 2 months ago #9938
Replied by Kiln_Red on topic Speedometer vs GPS Speed
The 928 speedometer almost always reads inaccurately these days. Just one of the many small 928 nuisances. Cleaning your grounds should restore the accuracy of all your gauges though. Always worked for me.
