ever loosening wheel bearings....
14 years 4 months ago #9290
I agree Malcolm, that is why I asked how to determine if the spindle is worn.
Replied by srshaw3 on topic ever loosening wheel bearings....
malcolm;9520 wrote: process of ellimination would determine that the bearing rides on 2 components so either one or all are worn.
Then whatever is determined to be the root cause is replaced with a new bearing.
14 years 4 months ago #9366
Replied by 928mac on topic ever loosening wheel bearings....
Hello Stan,
did you replace the bearing cup in the hub for each bearing assemble.
IMO that is where it is getting loose. If the hard cup was not perfectly clean and did not seat in the hub correctly, then as you tighten it or drive it the bearing cup will walk into the hub more causing the bearing to be loose. IMHO
this is why I said that when you tighten it really really crank it tight while turning the wheel against the rotation of the nut until you can not tighten it any more.
Then back it off and set the preload
This is the only thing I can think of that is wrong.
I hope it helps Stan, give it a try or take it all apart, wash the hub clean and see if you can see any space behind the bearing cup where it is not seated against the hub
www.google.com/url?sa=t&rct=j&q=bearing%...Y_HH24B_oXUloaLri_fQ
www.google.com/url?sa=t&rct=j&q=bearing%...x8eBzdzkb3PXuQONKtqA
14 years 4 months ago #9367
Hi Brad,
I think the cup you are referring to is what I call a "race". Yes, they were replaced. I suspect the spindle or hub is worn, as there was a "loose" issue before I swapped them out.
I checked the right side again last week, and it took another 1/2 turn of adjustment, and my suspicion is that it is now at the bottom of the threads, as I really could not turn it any farther with a reasonable amount of force.
14 years 4 months ago #9368
well, not necessarily convinced, but it is the direction I lean in, and it is what I plan to do next, I just haven't gotten to it yet
malcolm;9607 wrote: Stan,
if your convinced you have one side good one side bad then measure both and see if theres significant diff. then take steps.
Brad does have a valid point but given the amount of time its perhaps too late to get them correct.
