Timing belt tensioner question
14 years 6 months ago #8746
by the flying scotsman
hi Martin:
1) yes, especially if the car is fitted with modern cats
2) I live in Western Canada......no emisions test required
3) correct, see #1
I run my exhaust system with an X pipe and deleted the cats, the air pump and all the plumbing associated with.
Replied by the flying scotsman on topic Timing belt tensioner question
martinss;8919 wrote: Malcolm: Not to hijack this thread, but when you say the air-pump is not required is that because:
Thanks
- A well tuned car can still meet original standards without it?
- In your jurisdiction standards are lower or non-existent for this age of car?
- With a newer type of cat the pump is not required?
hi Martin:
3) correct, see #1
- smtcapecod
- Senior Member
14 years 5 months ago #9031
by smtcapecod
Replied by smtcapecod on topic Timing belt tensioner question
Of course, YMMV there are still many jurisdictions where the air pump is still 'required', because there is a blanket prohibition on removing any factory emissions equipment.
