- Thank you received: 9
Transmission part ID please
14 years 7 months ago #8268
Transmission part ID please was created by mm928
We are diagnosing some tranny leaks and suspect that the place in the pic below may be a small source. It is the yellow connector or seal where it connects into the Transmission.
However, I cannot seem to find it on the PET, at least not in the Transmission diagram.
We are thinking it is the kick-down linkage? Anyway, if anyone knows the part or seal or page where it is in the PET, please feel free. I do not think it is the biggest leak, but might as well do them all while we are at it.
Thanks!
Attached files [img]media/attachments/8440=952-trans_ID.jpg[/img]
Thanks!
14 years 7 months ago #8271
by the flying scotsman
Replied by the flying scotsman on topic Transmission part ID please
I believe that is the kickdown cable at the tranny end....its in PET
14 years 7 months ago #8274
Replied by 928mac on topic Transmission part ID please
Thats what it looks like to me as well.
I don't own a standard 928 but on any other car,
disconnect the cable under the hood, if there is a bolt holding the yellow down just remove it and lift up.
The cable will be attached to a hard wire hook that you will need unhook.
Have a small needle nose vise-grip ready so that you dont lose the hard wire inside.
replace the o-ring on the yellow piece and reassemble.
14 years 7 months ago #8282
Replied by mm928 on topic Transmission part ID please
Thanks for the fast response guys.
The PET reference is helpful Malcolm, looks like it is not on the tranny page, I guess thats how I missed it
Case closed!
Case closed!
