Coolings Fans Run Until Hood Opened
16 years 3 months ago #433 by 928mac
Thats it, take it for a short rip and when I park the cooling fan runs until the hood is opened. shuts off when alarm switch is up and runs when I push it down.
Dose not run when engine is stone cold and I close the hood.
Tack and speedo quit today as well. I must have a ground issue some where.
Anyone have any ideas where I should start.
Thanks, Brad
16 years 3 months ago #434 by srshaw3
I would advocate reviewing the grounds, they are a common problem issue.
B.W.Haugen;457 wrote: Thats it, take it for a short rip and when I park the cooling fan runs until the hood is opened. shuts off when alarm switch is up and runs when I push it down.
Thanks, Brad
16 years 3 months ago #435 by 928mac
Will do for sure, But I am finding it strange that the door locks are also acting up as it seems everything the alarm is connected to is not working correctly.
Is there a list of ground blocks/ connection points
16 years 3 months ago #436 by srshaw3
Greg's site has some good tips: nichols.nu/cat02.htm
Roger Tyson at 928srus.com sells the Jim Morehouse CD's. They are a wealth of technical information that you will be thrilled to have. Roger is a good guy, and 928 fanatic as well. You should be able to contact him through his website, or via This email address is being protected from spambots. You need JavaScript enabled to view it.
16 years 3 months ago #437 by 928mac
928racer;460 wrote: Greg's site has some good tips: nichols.nu/cat02.htm
Sweet, maybe we can just start listing these kind of links for others to use on our site.
16 years 3 months ago #438 by 87 Shark
Brad,
Found the attached last night on the Rennlist forum and the link with explanations is below.
members.rennlist.com/jerdmann...l.htm#anchor_2
Hope this helps.Found this on 928 forum under new visitor FAQ page 3.
Dave
Attached files [img]media/attachments/462=50-928 ground points.jpg[/img]
