Considering X Pipes for 1986.5
14 years 10 months ago #7285 by babromovage
Considering X pipes for my 1986.5. I live in PA and have antique plates for my car. This means I do not need an emissions test. Should I go with Xpipes without the cats? Or, do I get hi flow cats? Also, I have installed already the latest Porken Chip set. He had asked if I had X Pipes and I said I did not. What effect would this have no that I am considering putting the pipes on?
Any insight would be greatly appreciated.
Brian
14 years 10 months ago #7287 by smtcapecod
I have antique plates in MD, and planned along similar lines.
I opted to go for high flow cats, 100 cell count, available from Mandrel Bending Specialties on ebay.
I used an Ott x-pipe that I've had for years.
And built the system back from there. Well, actually, had a shop I'm familiar with build it back from there, using 928 Motorsports/Stebro v.1 mid pipes. With OEM final muffler, it is quiet, with no final muffler it is loud...I'm still in pursuit of "just right"...
I recommend talking directly with Ken. I believe the concern is that sufficient exhaust flow and improved scavenging of gases from the cylinders can lean out the fuel mixture to a point where the additional ignition advance and leaning of A/F ratio can give rise to concerns about detonation. IIRC, he provides advice to check the CO post-install and recalibrate the MAF if need be- if too lean conditions arise, and not that he has separate programming. But again, I recommend talking with him directly in case I'm mistaken.
Attached files [img]media/attachments/7455=812-x_Cars_dual.jpg[/img]
14 years 10 months ago #7319 by the flying scotsman
Not sure about your specfic Model year but the S4, GT and GTS models breath significantly better with a Xpipe. In my experience it might have been exagerated by partially plugged cats but either way it frees up the engine to freely rev.
From a noise issue my car was too loud with the x and RMB so I went back to a stock GT rear muffler with OEM small resonators...........perfect balance between power and noise level.
I do not run cats, dont have to but I would think of adding them if doing over as the car does emit unpleasant odour.
14 years 10 months ago #7321 by babromovage
Thanks for the insight
14 years 10 months ago #7323 by 928mac
Malcolm wrote: Not sure about your specfic Model year but the S4, GT and GTS models breath significantly better with a Xpipe. In my experience it might have been exagerated by partially plugged cats but either way it frees up the engine to freely rev.
Thats what that smell was
Just jokeing buddy, Brad
14 years 10 months ago #7331 by pcar928fan
Yea, w/o a cat they don't smell great, but it is not to offensive. How often are you sitting around at the rear of your car with it running anyway???
