Considering X Pipes for 1986.5
- babromovage
Any insight would be greatly appreciated.
Brian
- smtcapecod
- Senior Member
I opted to go for high flow cats, 100 cell count, available from Mandrel Bending Specialties on ebay.
I used an Ott x-pipe that I've had for years.
And built the system back from there. Well, actually, had a shop I'm familiar with build it back from there, using 928 Motorsports/Stebro v.1 mid pipes. With OEM final muffler, it is quiet, with no final muffler it is loud...I'm still in pursuit of "just right"...
I recommend talking directly with Ken. I believe the concern is that sufficient exhaust flow and improved scavenging of gases from the cylinders can lean out the fuel mixture to a point where the additional ignition advance and leaning of A/F ratio can give rise to concerns about detonation. IIRC, he provides advice to check the CO post-install and recalibrate the MAF if need be- if too lean conditions arise, and not that he has separate programming. But again, I recommend talking with him directly in case I'm mistaken.
Attached files [img]media/attachments/7455=812-x_Cars_dual.jpg[/img]
From a noise issue my car was too loud with the x and RMB so I went back to a stock GT rear muffler with OEM small resonators...........perfect balance between power and noise level.
I do not run cats, dont have to but I would think of adding them if doing over as the car does emit unpleasant odour.
- babromovage
Malcolm wrote: Not sure about your specfic Model year but the S4, GT and GTS models breath significantly better with a Xpipe. In my experience it might have been exagerated by partially plugged cats but either way it frees up the engine to freely rev.
Thats what that smell was
Just jokeing buddy, Brad
