Sunroof will not open
16 years 4 months ago #362
by CARLO
Sunroof will not open was created by CARLO
Hi,
On my 83' I replaced the SR switch and now have power to it. The motor spins about 1/8 turn and stops either forward or back. I pulled the motor and gear out and ran 12 volts to it. Jumped around like a frog, but spun fine. Is it possible the motor has lost it's torgue or is there something further down down the road I need to check. Thanks.
16 years 4 months ago #363
Replied by srshaw3 on topic Sunroof will not open
With the sunroof motor out, does the sunroof slide easily forward and backward?
There could be a misalignment or perhaps something in the sliding mechanism is jammed.
Also, while the sunroof motor is out, check the sunroof transmission for free movement as well.
16 years 3 months ago #368
by CARLO
Replied by CARLO on topic Sunroof will not open
Thanks, I will give it a try. It also leaks badly and is obviously not in it's home position. I will try and remove it.
16 years 3 months ago #369
My recollection is that with the sunroof motor out, it can be easily moved. If not then removing the sunroof transmission will allow you to.
Once it is straight the motor an transmission will probably work without issue.
16 years 3 months ago #398
by CARLO
I sent a reply yesterday but now do not see it so I will try again.
I removed the motor and gearbox, but cannot move the SR. It dips down at the rear about a 1/2 inch and is snug up front. Should I remove all the trim around the SR to gain some access ? Thanks.
16 years 3 months ago #399
You may need the manual, but Wally Plumley (an encyclopedia of 928 knowledge) posted this, that may help:
members.rennlist.com/pirtle/zbody_sunroof.txt
