Good morning June 11th
15 years 4 months ago #5092
Good morning June 11th was created by 928mac
Hello 928 fans
Working away on the car today.
2 steps forward and 1 step back seems to be the routine.
Still going forward but will have to run down for some coolant.
Dont use Dexcool, as a GM mechanic I can vouch that it is crap.
Aluminum compatible low silicate and phosphorus only. Color dose not matter.
G05 if its in your area or Prestone 50/150
Hope you all have a great 928 day
15 years 4 months ago #5093
Replied by 928mac on topic Good morning June 11th
1:00 o clock
I'm just so impressed that I got so much completed today.
Under the car is done.
Under the hood except the top rad hose because I have to run down and get some coolant.
I might pull the temp sender to help it bleed instead.
Have to put the in-tank pump back in, left out to drain last year and because it was leaking so I need to reseal it.
Then I can check the wires for the tec-gt ECM, 2 to hook up.
add fuel and connect the ground to the battery.
The program disk needs to be loaded and I have to pick the fuel and ignition map.
Cross fingers.
Now to wash up and head down town so the coolant can bleed while I finish the rest.
:burnout::burnout::burnout:
This has been way to much to Modify at once
Cross fingers.
15 years 4 months ago #5098
Replied by pcar928fan on topic Good morning June 11th
Great work Brad! Can't wait to see you have this car back on the road!
