Brakes
6 years 6 months ago #21105
by sky22blue
Thanks Trainer It doesn't do it all the time. I drove about 45 miles brakes were OK. Drove about 5 miles applying brake 8 -10 times before it started binding. Car has ABS and my left rear speed sensor is defective it is an early 86 and I can't find a replacement. . Engine bay around master cylinder area was very warm.
6 years 6 months ago #21106
by Trainer
When the washers are getting hard in the master it behaves that way. The problem will be intermittent not constant. Change the master and while you are at it you might as well overhaul the calipers as well. The age of the car suggests this is necessary.
