1980 Euro S 928 - Would it pass Calif. Smog??
- Charlie Hawkins
9 years 11 months ago #19437
by Charlie Hawkins
1980 Euro S 928 - Would it pass Calif. Smog?? was created by Charlie Hawkins
Hi group,
New member here with a quick question, I am considering buying a 1980 928 Euro S model. It is located out of state and has good service records, I will have PPI done but I am worried about the euro S model passing smog in my home state of California. Has anyone been through this? The cut off year for Smog exemption in California is 1976. If modifications are required, does anyone have a guess at the costs?
Thanks in advance for any input.
9 years 10 months ago - 9 years 10 months ago #19442
Replied by Kiln_Red on topic 1980 Euro S 928 - Would it pass Calif. Smog??
If the vehicle had been 'federalized' as it most likely was, then it will have the necessary smog equipment to pass the smog inspection.
Good luck with your prospective purchase.
Last edit: 9 years 10 months ago by Kiln_Red.
9 years 10 months ago - 9 years 10 months ago #19457
by Mal81
Replied by Mal81 on topic 1980 Euro S 928 - Would it pass Calif. Smog??
Hi,
I'm new to this forum also, so hope I'm replying appropriately / not stepping on any toes.
I've been through this with an '81.
You'll need to comply with the smog equipment and specifications for the year in which it was imported. This should be on a metal plate affixed to the drivers door pillar. Your car is 37 years old, as will be your emissions system, and all the other things: injectors, CIS, ignition - the 'green wire' , fuel pumps and filters, etc, etc. that make the vehicle run cleanly. You will likely have to inspect/test all of them (I certainly did) and do a bit of repairing and replacing of components to get through it. This is mechanical/vacuum emissions, so no OBDII diagnostics to help you!
I'm not a smog guru. Because of my ignorance, i spent months working on my car to get it right. I didn't have to replace my CAT or injectors (however, I have all new MBZ injectors ready to go in because the old ones are pretty well shot), but I sanitized my ignition and fuel systems, and used a wide-band O2 sensor and guage to help me tune the air-fuel mixture. I barely passed, had I installed a new CAT and injectors I'm sure my numbers would look a lot more comfortable.
Looking over its history, I suspect imy car has sat for many years of its life because it couldn't pass emissions. I bet the same is true of most ROW cars, because they weren't designed for emission controls. But there's hope: if I can do it, anybody can, AND you only need the emissions equipment and to meet the regulations that were in effect when it was registered on US soil.
One more thing: Be very careful of the shop and technician that you allow to smog your car. Most (IMO - Toes) are ... I n e x p e r I e n c e d when it comes to these ROW cars. Be Sure that if you are getting a 'diagnostic' test to check your progress, that the 'technician' (said through forced smile) is running the equipment in its 'diagnostic' setting (many don't seem to know there is one) so it isn't sending info to BAR. These.... 'Technicians' also will see things that aren't there, and look for stuff that shouldn't be there. Keep referring them to the emissions plate. INSIST THEY READ IT to you, if needs be. Also, nothing implied here but simple clarity of communication, only deal with someone who is a fluent English speaker (or at least fluent in your native tongue).
Other than that, piece of cake! (0:,'
PS: One more thing: DRIVE it before emissions testing. Drive it all you can, even thrash it a little. These engines really need it, and will respond by running better and better.
Last edit: 9 years 10 months ago by Mal81.
