Driver's side window switch fix and plans
12 years 7 months ago #16940 by mm928
Hi everyone, I have not been posting much during the winter months,,,, lots to do at home and at work.
I took my car to get inspected and lo and behold, if your power window does not work it will fail! Never thought of that. I replaced both window switches last fall, no problem then, but shortly after the drivers side motor went out, so I had to replace it.
Unfortunately, after I buttoned it up, the driver side would then only roll up. I knew everything in the door was ok as I had just replaced and tested it. But once buttoned up,,,,! ugggh
So I left it for a few months waiting for warmer garage temps. When it failed inspection I was forced to dive in,,, but that was a good thing and it was a nice weekend (finally).
Long story short.....the new switch I bought was now bad! Luckily I had the old passenger side switch (which of course is normally much less used than the drivers side) and tried it voila! Worked like a champ. Lesson is probably that the 36 dollar after market switches may not be worth it and you might consider the 75 dollar real ones.....or something closer. Also, the finish and window Icons on the cheaper ones were not that good.
After i enjoy my electrical fixing prowess...lol....I will probably go for Paul's solid state switch pad replacement solution.
Next is to replace the fan motor with Roger's solution,,, I am losing a bearing,,, it is squeaking, but only when I turn right... HA Then maybe braided brake lines.
Then back to the switch replacement. I really only have paint (long term) left do as a "big" thing. For my purposes, I am about 95% done with the car. After those things,,, anything else is gravy.
Pics finally later this spring or summer..... summer? YEAH please@@@@@! I am tired of weekly snowstorms in VA......
12 years 7 months ago #16947 by wallyp
You might want to check the blower and make sure that there isn't a leaf or something hitting the fan. You might also see if you can get some oil into the bearings...
12 years 7 months ago #16948 by mm928
Thanks Wally, will check both when I get in there, otherwise it seems to run fine, so you never know!
12 years 7 months ago #16974 by AirtekHVAC
Good work...I like the solid state window switches too, but low on the budget line right now.
My blower was the 2nd thing I took out of my car when I got her, the first being the CE panel. I drilled a hole in the top housing and sprayed oil in it...did not help, BUT...it was rusted stuck, and had gotten a lot of water in it the 19 years it was dormant. I was able to free it up, and now it is a spare (found a newer model one cheap, which was in excellent condition).... Point being , lube it up...can't hurt...
1978 5sp #30 - Rescue
1979 5sp - Rescue
1982 5sp. - Rescue
12 years 6 months ago #17002 by mm928
I am sure you will have a lot of handy tips like that bringing that one back to life! Ha
12 years 6 months ago #17123 by Normy1
This sounds like the window switch is bad. Tony over at the other website might have some ideas for you...
I don't talk about that rWebsite any more, since it continues to employ an ANUS from San Diego.
N-
