928 S4 Engine Project
12 years 6 months ago #17020 by 928mac
Replied by 928mac on topic 928 S4 Engine Project
normy;17411 wrote: by the way....how do you know it is an '87? Look up the casting number: It is near the front top of the engine, a square section to the left of the large round hole where the water goes in. It is obvious in your third picture-
my '85s2 has a number m28-21, with 519 below it. Your car should say m28-47, with your engine's serial number. According to people on that website that starts with r, the people in stuttgart can pull up a card that tells all about the car this engine was built with. Including the exact person who built it.
N!
lmao
12 years 6 months ago #17028 by 1989porsche928
thanks for replying. I am taking the photos from my galaxy note 3 cell phone. Believe it or not the block is almost perfect (besides rusted flywheel). It does have alot of gunk on it. Almost anywhere on the block i can spray a little brake cleaner or grease remover and with a little elbow grease it is shiny again. I have not been able to work on the engine since last post. I busted my knuckle open removing the starter bolt, its almost better now. I will probably order the tool to remove the flywheel tonight. Right now my plan is to take the engine apart and clean it. Then I will inspect all the components. I am tempted to send off the crank to have it micropolished and chaffered.
12 years 5 months ago #17045 by 928mac
wire brush the flywheel. rust is not an issue
12 years 5 months ago #17064 by 1989porsche928
928mac the flywheel is not compatible with an 89 they change the flywheels that year or the year before. I finally got the tool in from sears. it is a 12mm triple square bit. it looks very strong. Unfortunately it decided to get cold in NY again so I can't work on it today. I did notice a scratch so the engine will probably have to be bored or plated after i take it all apart. Have you guys seen anyone bore it alot and put in a sleeve or liner? I dont think it is impossible.
12 years 5 months ago #17073 by wallyp
Replied by wallyp on topic 928 S4 Engine Project
"I did notice a scratch so the engine will probably have to be bored or plated..."
It would have to be a serious scar before I did anything to the cylinders.
12 years 5 months ago #17077 by 928mac
I'm with Wally on this. can you get a good picture. It may be hard and sometimes with out a flash is better. There are guys in Cal LA that have made very successful over bores.
It is pricey though.
If you have an extra $30-40 grand I have seen 6L engines that look stock and deliver California emissions.
Lets start with I picture.
