- Thank you received: 9
Well isn't that just typical? Happen to you?
13 years 2 months ago #15413
Well isn't that just typical? Happen to you? was created by mm928
So I get my new Bilsteins on and S4 springs.....ready to beat the band.....then on the SAME DAY within 1/2 hour, my driver side window rolls down only 1/2 way and stops dead.....figures.
So I get 2 new window switches and put them in,,,,,did not fix it. The passenger switch worked and I used that one on the drivers side just to make sure. But it was starting to be hard to press so I just replaced both, it was time.
So at some point I need to tear into the door and check out the motor and wiring there. But I guess that was needed anyway since I have new rubber for the bottom seal and the window rattled so I can tighten up that too. But I wanted to enjoy it for at least a DAY... HA
With that said -
How many times have you just finished something and whammo! Something else happened - tell us your story!
With that said -
- emmanuelli
- Elite Member
13 years 2 months ago #15420
by emmanuelli
Replied by emmanuelli on topic Well isn't that just typical? Happen to you?
hmmm too many! lol i had my clutch replaced, rev sensor and couple other things last year, then out of no where, steering rack gave out and all the powers steering fluid came out. this was one moment it was all good, next morning it was all gone.
13 years 2 months ago #15424
Replied by 928mac on topic Well isn't that just typical? Happen to you?
Oh God I hope I'm done with anything more going wrong.
13 years 2 months ago #15432
Well I new I should not have responded and tested fate.
Wife and I took the car down town and she started to get hot. The car that is.
Stopped and checked the fans and they were both stuck. The motors are tight. Dam.
Ill take a look at them later when things cool off so in the garage it sits.
The AC in the Tundra is much better.
13 years 2 months ago #15438
Replied by mm928 on topic Well isn't that just typical? Happen to you?
Well there you go!
