Suggestions - Spider Emblem attach
13 years 3 months ago #14678 by mm928
Hey guys and gals,
I am finally getting the Shark back from the engine pull on Monday. I have a brand new metal Porsche badge to affix to the Spider. The Spider is powder coated so it is smooth. I have to cut off the tines on the back of the emblem (hood emblem) then glue, epoxy it to the nicely smooth finish of the Spider main body.
So - what to use?
JB Weld
Gorilla Glue
Adhesive made for auto/marine
Adhesive made for hi-temp
Super Glue Gel
Hi-temp Silicone sealant (ATV)
etc.
And should I seal the edges as well with something clear? or just leave it if there is a tiny gap? I do not want it to look goopy.
What have you had success with or summize is the correct thing to use? I assume it is never coming off unless it is re-powder coated, but I would not want to tear up the emblem or body trying to get it off. On the other hand I do not want to open the hood one day and see it gone!
The thing that worries me is the smoothness of the Spider body and the relative un-stickyness of the back of the emblem since it is some kind of pot metal.
Any ideas before Tuesday???? :) thanks
13 years 3 months ago #14679 by Kiln_Red
I used windshield urethane once. I was able to get the emblem on flush with little cleanup effort required. I just wiped off the unwanted urethane with lacquer thinner on a rag while it was still wet. It would be a major PITA to remove now, but it could be done with a putty knife affixed to an air hammer. If one thing is for sure it's that it won't be coming off by surprise.
13 years 3 months ago #14686 by mm928
Good one Austin, had not thought of that!
13 years 3 months ago #14695 by Ducman82
used simple 30min epoxy from the auto parts store. works GREAT
13 years 3 months ago #14720 by mm928
Ok, so it looks like I am overthinking this then huh? :) Looks like lots of things work fine.
thanks guys....
13 years 2 months ago #14754 by 928mac
I use an automotive contact cement for most stick on items. talk to your auto parts place.
