Thinking of pulling the engine
13 years 6 months ago #13785 by snowglobe
I took my 928 to the shop on Friday due to a coolant leak. I had purchased parts to refresh the fuel lines, PKT, TB, WP, and am looking to do more, but I've done nothing with them. Looking to finish equipping my garage.
I saw a thread on custom engine mounts on rennlist and am considering the Jegs stand mentioned in the first post:
forums.rennlist.com/rennforums/928-forum...-stand-adapters.html
www.jegs.com/i/JEGS+Performance+Products/555/80059/10002/-1
Still no idea about a hoist, although a google search turns up many. Any recommendations?
My liftbars arrived last Friday, I have four 12 ton jack stands and a Costco 3.5 ton jack.
I'm wondering what else to get in order to safely remove and work on an engine (and put it back in! arg), or do a TT service on the 928 (to put in Constantine parts).
--Jim
13 years 6 months ago #13788 by mm928
Well - if you are not in a big hurry, I am pulling mine likely this weekend. My friend has the equipment. I have the same stands, bars and lift jack from Costco that you do!
I will be glad to let you know what he uses as a hoist when I get over there as well as the engine stand. I have an 83 US auto, so our engine bay should be pretty similar.
13 years 6 months ago #13806 by wallyp
I would suggest a heavy-duty hoist with foldable "legs". These take up much less room when not being used.
An adjustable bar that balance engine weight and allows tilting the engine is helpful.
You need a really good engine stand - the 928 engine is heavy and top-heavy. Since it is really nice to be able to rotate the engine on the stand, a gear-driven rotation is expensive, but makes it easier and safer to rotate the engine to work on the bottom.
13 years 6 months ago #13807 by Kiln_Red
For curiosities sake, is there any specific reason or maintenance that you have in mind that requires removing the engine?
13 years 6 months ago #13812 by 928mac
Both the engine crane and the engine stand that I bought have folding legs. it saves a lot of room and headache.
13 years 6 months ago #13818 by xstepson
wallyp;14164 wrote: I would suggest a heavy-duty hoist with foldable "legs". These take up much less room when not being used.
+1 on all this, but the adjustment bar really makes the pull and reinsertion of the engine go smoother.
Buy at least a 1000 lb engine stand. They generally have a wider and heavier base. Nothing worse that turning over the engine on the stand and it toppling over.DO NOT ASK ME HOW I KNOW THIS.
I have calculated that 8 quarts of oil on your garage floor seems roughly enough oil to cover the state of Rhode Island at least a millimeter deep.
