Wheel fitment
- rluvsporsche
14 years 7 months ago #8463
by rluvsporsche
Wheel fitment was created by rluvsporsche
Hi All,
Need some friendly input on wheels I'm looking to buy use. There 18" 8 & 10 wide. They have front offset 52 and the rears are 65.
Will these fit 87' 928s4?
Thanks in advance.
Ariel
Thanks in advance.
Ariel
- smtcapecod
- Senior Member
14 years 7 months ago #8489
by smtcapecod
Replied by smtcapecod on topic Wheel fitment
Fronts are very dicey. 52mm would be close with 7", I think with 8" they will be at or past the edge of the fender and put you at risk of damage from big bumps. Also, 52mm would be likely to cause greater tramlining. Rears should be OK.
14 years 7 months ago #8490
by the flying scotsman
Replied by the flying scotsman on topic Wheel fitment
I run Carerra III wheels that were OEM on the 997
18x8" 57mm and 18x10" 58mm
14 years 7 months ago #8495
Steve,
That is not correct for the fronts.
An 8" with a 52 is AWESOME! Bigger ET is better on the 8" front wheel. I have Carrera Light Weights that are 8" and ET50...THEY are close but work. At least with 225 tires.
7" with a 52 would not be correct I do not believe, nor do I think you will find one that size anyway...but I could be wrong about this...
Replied by pcar928fan on topic Wheel fitment
smtcapecod;8663 wrote: Fronts are very dicey. 52mm would be close with 7", I think with 8" they will be at or past the edge of the fender and put you at risk of damage from big bumps. Also, 52mm would be likely to cause greater tramlining. Rears should be OK.
Steve,
14 years 7 months ago #8502
by 87 Shark
Replied by 87 Shark on topic Wheel fitment
I also run50 ET with an 8inch rimand 225 tires. ET 65 on the back with 265 tires fit fine but i will be getting 15mm spacers as the setupdoes not fill the wheelwell like the front.The spacers also give a finall 50 ofset wich is sprc for the car. this setup looks great and no handling issues.
