Which water pump is the best
13 years 3 weeks ago #15939
Which water pump is the best was created by 928mac
Over the past few years, here on the forums, i have heard a few different opinions on the different water pumps available to us.
So lets talk about every thing you know about water pumps.
How many are there 2, ...3, ...4 pumps maybe.
good bearings, .... bad bearings
good impellers, ... bad impellers
what are the stats?
Thanks for your help
what are the stats?
13 years 3 weeks ago #15940
by Ducman82
Replied by Ducman82 on topic Which water pump is the best
i know of the Laso pumps. i have used one from Roger. non issues
porsche pump is some serious coin.. like 1200 bucks
there are some remans with the metal impeller still. ick.
13 years 3 weeks ago #15943
by the flying scotsman
Replied by the flying scotsman on topic Which water pump is the best
there are made in China (or somewhere cheap) knockoffs.
there are at least 2 if not 3 versions from Laso
then theres the super expensive Porsche unit
I just installed a new Laso last winter on the GTS, the latest version with improved bearings and plastic impeller.....fit and functions perfect.
Phone Roger, he'll get you all set
13 years 3 weeks ago #15944
Thanks Malcolm, how much did your new Laso pump cost
Replied by 928mac on topic Which water pump is the best
malcolm;16316 wrote: there are made in China (or somewhere cheap) knockoffs.
13 years 3 weeks ago #15948
Replied by mm928 on topic Which water pump is the best
I have Roger's water pump as well, put it in this summer.
- rluvsporsche
13 years 3 weeks ago #15951
by rluvsporsche
Replied by rluvsporsche on topic Which water pump is the best
I've replace the pump 2 times for past 13 yrs using Laso. Although I wonder how long these units really last. I replace the pump when I do the belts even if they are not broken. I still have one the old Laso in a box. It makes me wonder if it still a good unit to use.
