Oil Filter Change without raising the car
- townofheroes
14 years 6 months ago #8799
by townofheroes
Oil Filter Change without raising the car was created by townofheroes
If you'd like to remove the oil filter without lifting the car or should it be can you, how does one do so?
I'm assuming the splash panel has to come out?
Is the splash panel all one piece?
And, where is the oil filter on a 1987 928?
I know strange question but I have made promises concerning not jacking the car up and getting under it.
I used one of those pumps to remove the oil and here I am wanting to replace the oil filter.
Thank you in advance.
14 years 6 months ago #8800
Replied by srshaw3 on topic Oil Filter Change without raising the car
Well, perhaps not in the spirit of your promise, but you wouldn't need to be under the car.... you could use a auto rotisseries or auto tilter
14 years 6 months ago #8801
by the flying scotsman
Replied by the flying scotsman on topic Oil Filter Change without raising the car
Porsche recommend changing the filter with every oil change.
As the filter is on the same side of the block as the drain plug the car should be level to drain all of the +8L.
If you dont want the car raised as the concern is upsetting the suspension the only alternative I know of is drive it over a pit. Yes, you have to remove the undertrays.
- townofheroes
14 years 6 months ago #8806
by townofheroes
Replied by townofheroes on topic Oil Filter Change without raising the car
I've already vacuumed the oil out. So I'd like to remove the splash screen and reach under and remove the oil filter.
Do you know if I can remove the splash screen without raising the car?
- townofheroes
14 years 6 months ago #8807
by townofheroes
Some inventions are looking for a problem to solve but the invention in the video link won't help me
- townofheroes
14 years 6 months ago #8808
by townofheroes
Malcolm,
which "under tray" do I need to remove to access the oil filter?
Apparently there are two front undertrays from the pics I saw on the web.
Thanks in advance.
Thr front tray has to come off but I remove both as they're bolted together.
I dont know how youd get them off without a pit or lifting.......theres not enough clearnace.
Thanks in advance.
