Engine removal
14 years 8 months ago #7934 by denhamfly
Engine removal was created by denhamfly
I am looking at the picture in the shop manual to hook up the host to remove my engine, and I can’t see were they want you to hook up the host anyone know a good spot to hook it? pictures of removal: s1125.photobucket.com/albums/l581/denhamfly/#!cpZZ1QQtppZZ20
14 years 8 months ago #7935 by srshaw3
Replied by srshaw3 on topic Engine removal
denhamfly;8106 wrote: I am looking at the picture in the shop manual to hook up the host to remove my engine, and I can’t see were they want you to hook up the host anyone know a good spot to hook it?
If they haven't been removed, there is a metal loop bracket in the left front and another in the right rear of your motor to use. If you don't have them, you can buy them and put them on. I don't have an '85 here, but I can probably get you a photo of the ones in my GT which are about the same as I recall.
You may know, but just in case, the 928 motor is really heavy, so use a hoist capable of at least 1/2 ton and similarly an engine stand.
14 years 8 months ago #7936 by 928mac
Replied by 928mac on topic Engine removal
Or if you are sitting in the car it is the right/pass front and left/drivers rear.
I could not find the drivers rear, not even with both hands, ha ha ha
Mine was missing.
You can buy them or make one.
When I set mine back in, I used the intake bolts but 2 bolts are not enough, you need 4 points.
14 years 8 months ago #7937 by denhamfly
Replied by denhamfly on topic Engine removal
I don't see any hooks where do they bolt to if i make them Thanks!
14 years 8 months ago #7938 by srshaw3
denhamfly;8109 wrote: I don't see any hooks where do they bolt to if i make them Thanks!
This photo shows what the back one should look like. I don't think you are going to be able to bolt it on with the motor in the car....
I think the front looks similar on your car, on my GT I think it is a more centralized bracket that looks different.
Attached files [img]media/attachments/8110=899-928_motor.jpg[/img]
14 years 8 months ago #7939 by srshaw3
928mac;8108 wrote: When I set mine back in, I used the intake bolts but 2 bolts are not enough, you need 4 points.
I was able to use the two points with an engine leveler.
