I think my cam is out of time.
15 years 5 months ago #4477 by 928mac
It looks like I screwed up and the exhaust cam is 180 deg out on the passenger side,
but yet the tit near the chain is on top and lines up with the colored chain link.
I think this one should be about 6-7 notches clock wise
This cam should be about 180 counter clock wise IMO
15 years 5 months ago #4483 by pcar928fan
You better get it figured out before you try and start it or you will need new valves at the very least!!
15 years 5 months ago #4484 by SeanR
You are way off on that.
15 years 5 months ago #4489 by 928mac
Ya when i slid the gears on sean the words were not pretty.
I just hope every thing is ok.
15 years 5 months ago #4500 by the flying scotsman
wheres #1 piston?
think about it Brad......with the crank @45 BTDC #1 then the cam timing marks should be 3 notches away from lining up correctly at 0 BTDC
I have a pic...hold it......from the '90 GT
15 years 5 months ago #4503 by 928mac
I got it done.
With the crank at 45 I rolled the cams to there correct position.
Brought the crank around to T/C
put the belt on and adjusted the gears.
Then I had to remove the belt again to put the cover in behind the belt :rolleyes:
