Wheel well cleaning
13 years 5 months ago #14601
by PCA0891
Wheel well cleaning was created by PCA0891
Hi friends.
Starting in the a m I will be removing my wheels and attempting to clean up all the mess that has accumulated over the last 24 years in the wheel well area including all associated parts.
Question: What "products" do you all think would work best in this application. I would like things to appear "as close" to new as possible. I'm sure that will be a tall order and most likely quite time consuming but it is next on my list. Anyone with helpful tips for this task I would sure be grateful.
Thanks in Advance
Thanks in Advance
13 years 5 months ago #14604
Replied by pcar928fan on topic Wheel well cleaning
Robert,
I always just tried to keep it simple...as in Simple Green! You need to rinse it very well after you are done with the cleaning though and get all residue and left over off the parts. Other than that it seems to be very safe and effective to me... DO NOT use things like Easy Off oven cleaner though! LOL! I accidentally got that on my anodized wheels once and that was NOT GOOD!!!
13 years 5 months ago #14618
Replied by mm928 on topic Wheel well cleaning
Good point. also it is an 88, on my 83 the back part of the wheel well is not metal, so if yours is not as well be careful.
I would think Simple Green is a good option as well to start with because it is not caustic and should work on oil....dirt....mud and other typical road accumulation. Maybe a good stiff horsehair brush etc. to break it up as needed. I would be careful using wire I would think.
13 years 5 months ago #14622
by Normy1
Replied by Normy1 on topic Wheel well cleaning
Forget about the Simple Green. Folks, this is 24 YEARS of grime! I recommend a high pressure hose, and a scrub brush with nylon bristles about 3 inches long. Get your self a bottle of Soft Scrub, maybe two.
For the front wheels, why not do it right and remove the plastic wheel well liners? There are a bunch of screws....just place them on a piece of paper about 25 feet away and make note of where they go. Pull the thing down [I've done it 4-5 times, it is not a big deal], and THEN go to town on it! When it is down, clean your springs. Use non-flammable break parts cleaner to clean the aluminum upper and lower A-arms; Dawn dish detergent is the best after you've gotten the baked-on grease off.
Reassembly goes easier if you take pictures first, but the huge plastic front wheel well liner is pretty self explanatory. The rear? Pull the wheel and get up there with the same scrub brush. You are going to throw this brush away, don't worry about it. Soft Scrub works best, make sure you get the springs.
Now, when everything is hosed down and eventually dry...
Whenever you wash your car, when you are done, make sure you shoot a shot of Armor-All in front of the front wheels, behind them, and then do the same to the rear. Once your wheel wells are clean, you want them to look as dark as possible, and Armor-All is best for this.
Little details such as clean wheel wells are what make people walk up to you and ask if a 28 year old car is new-
N!
N!
13 years 5 months ago #14627
by PCA0891
Replied by PCA0891 on topic Wheel well cleaning
Thanks for all the words of wisdom all. Yesterday I proceeded down to the local Auto Parts shop and found all the bits I need.
Two Jack Stands, One bottle of Simply Green and several different type's of wire brushes. I never really put my nose up inside the wheel wells to see how dirty the wheel well area's are on my car. you all were right 25 years and 75k worth of miles mess.
Jacked her up front end first, I don't really like the idea of my whole car up on stands at once. So I'm doing the front first. Removed my Turbo Twists and sprayed the insides down with Simply Green and scrubbed them down with my grill scraper the wire brush side. Rinsed them out and what a huge difference. I had these wheels refinished last winter and they look like the day I picked them up from the Wheel shop. Just wish there was a way to keep them looking like that all the time without having to remove them.
Now back to the project at hand. I took the high pressure sprayer to the well wells but I did not remove the actual inserts themselves. " To stupid to get them back in correctly". Anyway,, I got most of the big stuff off and then sprayed the entire wheel well down with Simply Green. I let it soak for about 15 minutes and then proceeded to scrape.
I was able to remove most of the big stuff with the long handled wire brush and then sprayed her off with water again. Thinking like I do I was hoping that would do it... Na. Next step. Hit it again with SG and I took a fist size wire brush and began to hit all the moving parts... OK, I'm about 3 hours in and finally the progress I was after. I then went to the other side...
Man what a difference. Everything was shiny and looking new again. Amazing stuff Simply Green. I was skeptical at first but that stuff really works well. Thanks for all the idea's guy's... It worked out well.
A short side story
Last winter when Austin and I had my car apart doing all the Refresh work I had thought about re-painting my Caliper's and so while the wheels were off and everything was as clean as it would ever be again, I went ahead and re-sanded down the Calipers sprayed them down and let sit overnight to dry.
This morning I strolled back down to Auto Zone and bought a fresh can of Daytona Yellow. I always thought that yellow would really set off the Black Paint and dark tinted windows my car came with. I then masked everything off and proceeded to change the whole look of the Beast. I taped off all lines, masked off everything including the whole fender and proceeded to spray. I'm happy to say that even with no prior experience and just reading through one of the tip forum's they turned out great...
I know have about 8 true hours of work done, the Wheel wells and Calipers look fantastic.
Tomorrow I will tackle the rear... Certainly a project with clear results.
My expectation is that the rear's will look just as good.
A short side story
13 years 5 months ago #14630
Alright, that is using some elbow grease....where do we send the Advil?????
