- Thank you received: 9
Euro vs US
I plan on adding a Y-pipe but that is about it. I am not sold on spending the bucks to supercharge it at this point. I think it runs fine right now, just want a little more. Not a lot.
crank, rods, pistons, heads etc althouh probably easier to find a complete engine.....I know where one is but along way from you:)
Strat_928;8559 wrote: What parts from the 16v Euro (like an 84S) can be used on the US 83S? Is it worth it to find and use them for any kind of HP gains? I had heard that you can use the heads and maybe another part or two.
There are a number if differences, cams, heads, and intake are commonly changed to get a modest hp gain.
This is what I was thinking - then consider the alternative of just getting the original engine right and tight and adding a Murph SuperCharger instead.
928MS y-pipe and hi-flow cat
Euro Intake
Euro Cams
Euro Heads
85/86 stock headers
And does this work make the engine an interference one? Also consider I have a 30$/hr mechanic along with myself to help.
But Stan's option of a good Euro engine outright is another way to go...!
I do really like it as-is, and I am doing the y-pipe this year. So that may be enough for now, enjoy as-is for a while then see if I want more.
Strat_928;8563 wrote: Hey thanks for the quick responses!
Euro Intake
Euro Cams
Euro Heads
85/86 stock headers
Credit where credit is due, Malcolm suggested the complete engine, it is a good plan, and easy to make if you can find a good engine when looking for your parts.
Whether it is an interference engine, is debatable. There seem to be more for it being so, than not.... but I wouldn't want to guess wrong, so presuming it is interference is a good plan.
My '80 Euro S when stock had 300hp as I recall. With a 5L bottom end, headers and a few tweaks, I saw one with 300 at the rear wheels, but it was track only, 100+ octane, etc.
A supercharger can get you over 300 pretty easily, and the higher compression might be a disadvantage.
