TOPIC: alternator low voltage while running
alternator low voltage while running 23 Oct 2019 10:16 #21030
  • mavche's Avatar
  • mavche
  • New Forum Member
My 1983 928 just began to indicate a problem, which appears to be a low voltage reading (10-12 V) while the engine is running. What are the most likely reasons for this? I've never had a problem during the past 28 years.
alternator low voltage while running 27 Oct 2019 04:57 #21032
  • nluk100's Avatar
  • nluk100
Could be a number of things.
1. Loose connection at alternator
2. Bad earthing of alternator
3. Alternator starting to fail due to age
Did you try pressing the corner of the instrument cluster where the gauge is as they circuit board is known to crack on some models.
'89 928 GT
Time to create page: 0.504 seconds
