I don't speak Portuguese but Google does a crude job of translation....
Good evening, I'm Portuguese and I own a Porsche 924 2.0 125cv.
I bought the vehicle at the auction and now I'm trying to get him to walk.
But he picks it up and goes downstairs. In other words, it has no relantity. Does not stay in rotation.
However as the accelerator is payed forward the cable a little so it is always with acceleration or is always working but at 2000rpm.
But he does not work anything right. Are you always working uncertain any idea whatsoever? Thank you
From this translation I would guess that it may have a vacuum leak since it will not run at idle speed but will run at 2000 RPM.
I suggest doing a compression test to confirm that the piston rings and valves seal well. If the engine has proper compression then look for vacuum leaks and other problems.
What you didn't tell us is if this 924 has the Audi 2-liter engine (Bosch K-Jetronic CIS) or has the Porsche motor (Bosch Motronic). The diagnostics for further help are very different based upon the engine.
