TOPIC: Inside door panel
Inside door panel 10 Apr 2020 07:22 #21182
  • Jjburns15
  • Jjburns15's Avatar
  • Jjburns15
Can anyone tell me the parts I need to replace the inside door panel on the driver’s side? It’s the part with the air conditioning louvers. There is a center bolt with cross piece but is there more such as plugs?
Thank you
You guys on here are great!
John
Inside door panel 11 Apr 2020 23:35 #21183
  • Posts:301 Thank you received: 17
  • Rich928's Avatar
  • Rich928
Hello John,
There is a Porsche Parts PDF document that has a lot of drawings, this is the door diagram.
However, every screw and plug isn't shown. You'll have to be careful and look where there may be fasteners, remove the screws and the plastic plugs that hold the panel in place.
You can send me a note with the model year of your 928 to 928ocmembership[@]earthlink.net [remove brackets] and I'll email you the file.
You can download the entire Porsche factory workshop manual in PDF form from: www.ligeti.com/928/
Last Edit: 11 Apr 2020 23:39 by Rich928.
Time to create page: 0.178 seconds
