TOPIC: Replacement Ignition wires, distributor caps and rotors and spark plugs
Replacement Ignition wires, distributor caps and rotors and spark plugs 01 Jan 2018 17:41 #20120
  • Posts:15 Thank you received: 1
  • mrgrinch2000's Avatar
  • mrgrinch2000
Going to take the plung over the winter to replace ignition wires, distributor caps and rotors and spark plugs.
Any recommendations on where to purchase?
Any advice to a first timer....lol
Mr Grinch
Last Edit: 01 Jan 2018 17:41 by mrgrinch2000. Reason: Spelling
Replacement Ignition wires, distributor caps and rotors and spark plugs 07 Jan 2018 20:52 #20127
  • Posts:1 Thank you received: 1
  • Boardncrash's Avatar
  • Boardncrash
  • New Forum Member
Most of the tuneup components can be found on eBay for a reasonable price.good time to peek at the timing belt also.getting the wires off the plug boots can be irritating.
The following user(s) said Thank You: y33trekker
Replacement Ignition wires, distributor caps and rotors and spark plugs 12 Jan 2018 10:50 #20136
  • Posts:63 Thank you received: 2
  • y33trekker's Avatar
  • y33trekker
I've found reasonable pricing for various parts (like the master cylinder I recently replaced) at Autohauz.
www.autohausaz.com/index.html
Replacement Ignition wires, distributor caps and rotors and spark plugs 17 Mar 2018 18:03 #20239
  • mrgrinch2000
Thanks for everyone's advice.
Made purchase through 928 Motorsports, Autopartsway and Pelican parts.
Will start the work next week.
Mr Grinch
Replacement Ignition wires, distributor caps and rotors and spark plugs 08 Apr 2018 21:37 #20287
  • mrgrinch2000
366 views and 3 replies.....Thanks for the advice from the 3 that took the time to give me some advice,
I guess the other 333 have no opinion or advice to give.
Just to let the 366 viewers know that the numbered wired wires cost more but made the job less stressful having to track what number wire was where.
The project was a success thanks for asking.
I appreciate the help.
Mr Grinch
Time to create page: 1.308 seconds
